I have an issue with the following settings
Automix Type = Fade (keep intro/outro)
Automix Length = 8s (also happens on the other settings)
Every second song the audio cuts out completely during the mix
So plays one track into the next fine, but the next one it cut out, next one fine, next one cuts out and so on.
I have tried full / smooth, different sound card settings. (and lots of other settings) Nothing seems to fix it
geposted Thu 30 Aug 07 @ 11:57 am
ok not managed to replicate this problem so all most certain it will be a config
problem with sound card try seting the sound card to auto and safe mode!
allso you need to try automix in both decks just in case it s problem only in one deck
and have you checked if it only does this with audio or video or both .does the
automix work in smart setting? .lol ade
geposted Thu 30 Aug 07 @ 2:36 pm
I have this problem as well. Songs in the playlist when automix is enabled are being skipped. I can actually get Virtual DJ to crash everytime using Automix = fade (with intro/outro). If i find a song that is skipped and double click it, it will fade to it for the amount of time specifed in the automix length and then it will immediately jump to the next song.
If i do the following however I can crash Virtual DJ everytime.
1. On the song that doesn't play I first set it to repeat.
2. I then select Automix = fade (with intro/outro)
3. Watch as the song immediately and continually fades to itself.
4. The song progress bar is blanked.
5. Virtual Dj stays allive for only about 10 secs before it crashes.
What information gets sent in the bug report? Cause i've managed to send a bunch of them in the last 10 mins. Hope those bug reports help.
Note: Automix does work with "Smart" and "Fade (without intro/outro)".
geposted Mon 17 Sep 07 @ 12:32 am
Can you write here the data written in your "crashguard report.txt" file please
geposted Sun 23 Sep 07 @ 10:17 pm
