Hi Guys!
Had a quick scan through the skins looking for one that is in 1400 x 1050 res but can't find one! Anybody know of any, ideally would be the standard skin just at that res!
Cheers
Cheers
geposted Sat 01 Sep 07 @ 2:25 pm
For the moment there are no skins in 1400x1050, as now most screens are widescreens so the resolution would be 1400x900.
You can read this topic: http://www.virtualdj.com/forums/75760/Skins/Skin_V5.html
to find skins in 1400x900
geposted Sat 01 Sep 07 @ 10:48 pm
I do happen to have one at 1400x1050 that is based on DJ Format's Mixlab skin. Unfortunatly as it's not all my work I've been greedy and kept it very quiet!
Should demad call, and I get an OK from the creaters, I may post it in the skin section.
The base skin with video active, but muted on the DJ's screen (saves CPU power)
Same again, But with video preview active.
Same skin, but with video "Supasize" active. Only good for those with fast CPU's, and yes it is overlayed over the recordcase, although you can still see title, and even load from the library while supersize is active, to see the full library, you need to turn supa size back off. Good for those that can't see a club TV, or want to sing along with a karaoke track!
geposted Sun 02 Sep 07 @ 7:58 am
halo - that looks awesome! would it be possible to get a copy?
geposted Sun 02 Sep 07 @ 11:59 pm
At this point I can't give it out, as it's version of DJ Formats MixLab skin, if I get an OK with him, I'll mod it for public use.
geposted Mon 03 Sep 07 @ 5:56 am
