Forum: Old versions
Topic: Upgraded to pro but .exe files won't open
Hi,
I upgraded to the Pro version today after finding out that i couldn't use an external mixer with the DJconsole version and Hercules MK2.
Unfortunately the .exe files for v4.3 and for v5 rev 2 won't open. It says .exe file cannot initialise and it seems that the expected file size is not the same as the actual file size.
Any ideas?
This is very annoying as I have a gig tomorrow night so trying to get it sorted out to use the club mixer.
Cheers Bob.
geposted Tue 04 Sep 07 @ 11:57 pm
Yep, right click the download link and select save as... use Internet Explorer if you use Firefox.
Thanks thats fixed it.
Now to learn how to use the new version by tonight!
Not a smart idea to install then gig the same day, you need to get your databases in order and make sure you have no screw ups before going live. Just a suggestion:)
