Hi,
I upgraded to the Pro version today after finding out that i couldn't use an external mixer with the DJconsole version and Hercules MK2.
Unfortunately the .exe files for v4.3 and for v5 rev 2 won't open. It says .exe file cannot initialise and it seems that the expected file size is not the same as the actual file size.
Any ideas?
This is very annoying as I have a gig tomorrow night so trying to get it sorted out to use the club mixer.
Cheers Bob.
Any ideas?
Cheers Bob.
geposted Tue 04 Sep 07 @ 11:57 pm
Yep, right click the download link and select save as... use Internet Explorer if you use Firefox.
geposted Wed 05 Sep 07 @ 1:30 am
Thanks thats fixed it.
Now to learn how to use the new version by tonight!
geposted Wed 05 Sep 07 @ 9:56 am
Not a smart idea to install then gig the same day, you need to get your databases in order and make sure you have no screw ups before going live. Just a suggestion:)
geposted Wed 05 Sep 07 @ 8:48 pm
