i had both working, then next time i start up vdj, only one table will work, then i start it up again and then the other works...
then both work...
any reasons for this?
Rich
then both work...
Rich
geposted Fri 07 Sep 07 @ 3:46 am
You mean the timecode signal right? I keep having the same problem. Everything is working fine one day. The next day I can't get a signal from my timecode or just the left deck will work. It happened today, I re-started the computer and they worked. Weird.. Mind you, not unplugging anything from the setup except the computer.
geposted Fri 07 Sep 07 @ 5:45 am
Well..it often happens to me with Maya 44 usb. It says "not enough channel" and works only one. I solve that closing vdj, unpluggin the audio card and pluggin it again. I don't know why. At the same time i don't know neither why sometimes my computer can't find drivers of my hercules and i have to install them when i plug it. Anyway... for look if Asio is workin with maya u can open the maya-audio-mixer utility and u will see the sliders (if everything is ok). If not, u wont see the sliders,
Peace, and sorry for my english
Dj Kad
Dj Kad
geposted Fri 07 Sep 07 @ 5:56 pm
Always make sure you plug in and enable the soundcard prior to opening vdj.
geposted Mon 10 Sep 07 @ 2:46 pm
ttt
geposted Tue 11 Sep 07 @ 6:41 am
