hi there,
how can I control the effects sliders using mk2? what im trying to figure out is how to control the effect sliders. I know I can use effects on mk2 by pressing effect buttons "1,2 or3". I NEEED SOME HELP!! thanks
geposted Sun 09 Sep 07 @ 8:03 pm
I would love to have that option as well but it would take way too much mapping to make that happen... So my suggestion is to practice with the MK2 as far as selections and use the mouse to the use wet / dry / volume functions... It may be inconvienced but it's very quick once you get used to this method.
geposted Mon 10 Sep 07 @ 11:46 pm
thanks!! is there any other way besides using the mouse?
geposted Tue 11 Sep 07 @ 12:04 am
you can setup keyboard shortcuts options > keyboard shortcuts
or use a controler such as the numark DMC2 or total control or mk2 dj console
geposted Tue 11 Sep 07 @ 5:08 pm
I am using Dj Cel's mapper and I mapped Bass, Medium and High knobs to control effect sliders. If you want, I can send you my preset to make it easy for you ;) Just note that I use external mixer, so I use MK2 as a controller only, not a mixer.
geposted Sun 16 Sep 07 @ 8:37 pm
