I'm using 5.0 rev2 and when I clone the deck, they are not on beat. Not a big issue, but just wanted to see if there is a fix that anyone know's of. To clairify, when I clone the deck its about less than half a beat behind. Any idea what? Never did it before.
BTW, everything else is working great now with my TCV, once I fixed the pitch sensitivty. Thanks for the info!
geposted Sat 29 Sep 07 @ 11:40 pm
noted same here, will bring it on to dev team
geposted Mon 01 Oct 07 @ 11:30 pm
I though that all depends on how you've set your latency. I know when I set mine to less, it worked fine. But when it's more, the clone deck is not always on point.
It also doesn't completely lock on beat when I have my safe mode and overclock checked.
But then again it all varies on different pc's, give it a shot and see.
geposted Tue 02 Oct 07 @ 6:16 pm
last i heard i thought that was a mk2(dac or other midi device) issue and since corrected. My clone works perfect with tcv.
geposted Wed 03 Oct 07 @ 8:33 pm
