I have had issues where Virtual DJ stops responding to any commands that involve playing the music. The crossfaders and volumes work. I forget whether I can load new songs or not while it is frozen. It happened about 3 times so far. I will try to see what else I can control next time it happens.
One of the troubleshooting steps I like to take is to disable hyper-threading for the program temporarily by going to the Task Manager (Ctrl-Alt-Del) and right clicking on the process and setting the affinity to only use "CPU 0". I will see if this prevents the issue.
I found a useful program I would love to share with the Virtual DJ comminity, the ImageCFG Affinity Mask Tool. It permanently forces the program to only use" CPU 0" any time the program starts. It prevents having to go the the Task Manager to disable "CPU 1" all the time. You can find it here:
http://www.robpol86.com/Pages/imagecfg.php
I have the "BCD2000 2.1 Mapper" installed and have "BCD 2000 ASIO" selected as the output sound card.
Latency is set to 4 ms for the "BCD2000 ASIO" in "B-DJ" mode.
Here is my performance settings as of now:
Note: Press "Alt"+"Prt Scr" to take a snapshot of only the window selected. It prevents having to open any graphics program and cropping the screenshot.
My Current PC Configuration:
Desktop PC Brand: None, custom built
Monitors: Two monitors, one for me and the other for the crowd to see videos and pictures at a resolution of 1024x768
Power Supply: PC Power and Cooling 510W
CPU: Intel Pentium 4 3.4 GHz Hyper-Threading (AKA Hyperthreading) 650 Prescott 800 MHz FSB LGA 775 EM64T
Video Card: BFG NVIDIA GeForce 7800 GTX OC 256 MB GDDR3 PCI Express x16
RAM: 2 GB RAM Corsair XMS2 SDRAM DDR2 533 (PC2 4300)
Sound Card: Creative SoundBlaster Audigy 2
OS: Windows XP SP2
Keyboard: Logitech G15
Mouse: Logitech G5 Battlefield 2142 Edition
Speakers: Logitech 5.1 Speakers Z-640; I set the rear left and right rear speakers to output the same left and right from the front to immerse the audience.
Optical Drive: LITE-ON Black 16x IDE DVD Burner SOHW-1693S
Hard Drives: 3 Internal Seagate Barracuda 7200.8 ST3250823AS 250GB 7200 RPM Serial ATA150
Printer: Canon iP4300
Headphones: Pioneer HDJ-1000
Audio Hardware: Behringer BCD2000; Behringer BCF2000; Behringer XM8500 Microphone; Yamaha PSR-290
All hardware drivers are checked for the latest version every week.
OS: Windows XP SP2
geposted Tue 02 Oct 07 @ 7:11 pm
GargantulaKon wrote :
I have had issues where Virtual DJ stops responding to any commands that involve playing the music. The crossfaders and volumes work. I forget whether I can load new songs or not while it is frozen. It happened about 3 times so far. I will try to see what else I can control next time it happens..
When this happens, does the skin browser part get cluttered? Where for example the sampler engine and browser is shown at same time and similar.
geposted Tue 02 Oct 07 @ 7:54 pm
Cluttered as in garbled such as a graphics engine bug? No, I have not seen that happen. I forget whether or not I can access the other tabs such as browser, effects, etc. Next time it freezes I can capture my desktop in a video to show exactly what happens and can post it in this thread.
I updated my blog with more details on how to use the Hyper-Threading tool. I thought it might be useful for others.
http://www.virtualdj.com/blog/GargantulaKon/
geposted Tue 02 Oct 07 @ 8:09 pm
Well, it happened again. I got it recorded with me trying to get it started again. This makes me not want to try playing with this current setup live anymore. I was so excited with discovering the BCD2000 mapper. I am going to try to troubleshoot the problem. Any help would be great.
geposted Wed 03 Oct 07 @ 6:09 am
It happened again after doing the same thing, loading a video. Here is another video with a yellow circle around the cursor to show where it is and a red circle to show when I am left clicking on something. Hopefully this can help the developers. I am happy to help, just ask questions.
I made a discovery! I can play the songs again after a freeze without having to restart VirtualDJ and even the video when I go to my config window and selecte another ASIO driver and go back to the BCD2000 ASIO. The driver seems to just give up.
geposted Wed 03 Oct 07 @ 6:29 am
