Hello,
is this card fine for video ATI Radeion HD 2900 XT
geposted Mon 15 Oct 07 @ 1:17 pm
1024 MB GDDR 4
geposted Mon 15 Oct 07 @ 1:49 pm
I would say save your money, its a bit of overkill. I run the X1950 pro and it is a great card:)
geposted Mon 15 Oct 07 @ 11:52 pm
I would say that card is ok to me but take advice from those who use ATI cards n u won't be sorry:)
N....Pls dun double post, u already have ur answer here.
http://www.virtualdj.com/forums/78689/General_Discussion/ATI_Radeon_HD_2900_XT.html.
thks.
thks.
geposted Tue 16 Oct 07 @ 11:43 am
Yes, I agree, a bit of overkill, you can go with ATI 2600 PRO or XT with 256MB DDR3 for video use.
geposted Mon 22 Oct 07 @ 11:24 pm
The team says:
Minimale Anforderungen
Die minimale Anforderung, um Virtual DJ laufen zu lassen ist:
PIII 850 MhZ Computer
1024x768 SVGA Grafikkarte
DirectX kompatible Soundkarte
512 MB RAM
20 MB freien Festplatten Speicher
Die empfohlene Konfiguration ist:
PIV 3 GhZ Computer
4.1 DirectX kompatible Soundkarte (mit seperaten front und rear outputs)
1024 MB RAM
200 MB freien Festplatten Speicher
512 MB RAM
PIV 3 GhZ Computer
1024 MB RAM
geposted Thu 25 Oct 07 @ 5:30 pm
Yes, but I as a computer shop owner suggest:
Intel P35 Chipset based motherboard (Foxconn or MSI)
Intel Core 2 6750 2x2.6Ghz, 4MB cache, 1333Mhz FSB
2 or more GB of ram at 800Mhz (it's VERY cheap these days ;) )
ATI Radeon 2600 PRO or XT with 256MB DDR3
or
NVIDIA 8600GT or 8600GTS with 256MB DDR3
500GB WD
The rest is up to you ;)
or
500GB WD
geposted Sat 27 Oct 07 @ 12:26 am
Alf you forgot the most important component recomendadion....the sound card, since as a DJ application, you don't want your weak link to be a shotty soundcard giving you shotty sound.
geposted Sat 27 Oct 07 @ 5:08 pm
soudcard
M-Audio Delta 1010 LT
geposted Sun 28 Oct 07 @ 7:33 am
