Forum: VirtualDJ Plugins
Topic: DMC-2 mapper v1.2 is now available
I have just released an updated version of the DMC-2 mapper. This fixes a few bugs and adds a few new features:
  • Video effect and transition names are now shown in video mode.
  • Optional frame cueing mode implemented (Enabled via user parameters.)
  • Effect and video effect buttons can be selected and pressed.
  • Effect and video effect sliders can be selected for adustment.
  • AUTOMIX button now works correctly when double-clicked.
  • Random video transitions now work in automix.
  • User parameters can now be filtered by group.
You can download the new DMC-2 mapper from Downloads -> Plugins -> External Tools:
http://www.virtualdj.com/addons/download.html?addon_id=3443
geposted Tue 23 Oct 07 @ 8:43 pm
YESSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!
Cheers mate, you just KNOW I've been waiting for this one!
Jonathan, I'll be using this at the weekend & will report back.
geposted Tue 23 Oct 07 @ 8:59 pm
jpboggis,
Just installed it and it looks good, except one thing:
When I hit the automix button at my skin on the laptop it mixes great.
But when I hit twice the automix button on the DMC2 it starts with the automix but it stops after the first song.
Any idea?
geposted Wed 24 Oct 07 @ 10:26 am
The automix on the DMC2 isn't for using with VDJ automix (technically) If you hit that button twice it will slide over to the other deck mixing whatever you have loaded on that second deck in.
geposted Wed 24 Oct 07 @ 11:35 am
Thanks Tophouse.
Thought that it would start the automix from the vdj automix.
geposted Wed 24 Oct 07 @ 11:43 am
You can toggle automix on/off by holding down WHEELMODE on the appropriate side and pressing AUTOMIX.
geposted Wed 24 Oct 07 @ 7:58 pm
jpboggis,
That's very nice.
Thanks for this great upgrade.
Works fine.
geposted Wed 24 Oct 07 @ 9:39 pm
vfdjPRO InfinityMember since 2004
Hello.
How to modify the jogwheel speed to have the same effect like the nudge mode on the default config ?
Marvellous mapper !
geposted Wed 07 Nov 07 @ 6:25 am
That's a good one !!!
When I use the wheel for scrolling trough the music, it goes to fast.
geposted Wed 07 Nov 07 @ 7:42 am
You can adjust the jogwheel sensitivity via user parameters (See the section at the end of the manual (DMC2Mapper.txt))
E.g: 'Jogwheel Pitch Bend Sensitivity' and 'Jogwheel Browse Speed'.
geposted Thu 08 Nov 07 @ 6:24 pm
Thanks jpboggis !!!
Great, gonna have a look now.
geposted Thu 08 Nov 07 @ 7:06 pm
Is it possible to have a french translation of the .text because I'm not so good in english and I don't understand all.
The mapper seems very nive but with no translation, I can't use it perfectly .
Anyone ?
THX.
geposted Thu 08 Nov 07 @ 7:27 pm
Sorry, I don't speak French (Or any other languages apart from English.)
NOTE: It's also possible for the DMC-2 displays in the mapper to support other languages too, if someone is able to translate the text definitions.
geposted Thu 08 Nov 07 @ 8:06 pm
Just tested scrolling trough the songs after changing it.
It's perfect now.
Thanks jpboggis
geposted Thu 08 Nov 07 @ 9:50 pm
Don't worry. You already made a big big work.
THX.
geposted Sat 10 Nov 07 @ 5:48 am
