hi, im having some trouble and any help would be great cos im loving the new version (and my new controller) but this is taking the shine off it!
i recently purchased a behringer bcd3000 and also upgraded versions of vdj. if i use the ASIO driver of the behringer for the soundcard the sound just cuts out after around half an hour playing (or quicker if im trying to use other apps at the same time). it seems near identical to an issue another person on the forum brought up concerning the bcd2000 ASIO driver.
http://www.virtualdj.com/forums/77958/PC_Version_Technical_Support/Hyper-Threading_Issues_.html
this wouldnt be such a bother if i had an alternative, which brings me to my next problem...
using my normal sound card (Soundblaster Live! 5.1) as the soundcard for VDJ i get little crackles when i move or fader or turn a knob (both on the controller and if i move them directly in VDJ). Is this soundcard incompatible with the new versions of VDJ? it worked fine with v3.4 which is what i was using previously.
i can see why there might be issues with the behringer ASIO driver and its not specifically supported by VDJ so no real qualms there, but i would have thought my sound card would be fine?
any help would be much appreciated!
geposted Wed 24 Oct 07 @ 12:30 am
In both cases, it's an USB component so can you try with your internal sound card. If you don't have crackles, verify IRQ conflict and/or USB bandwidth
geposted Wed 24 Oct 07 @ 12:40 am
not sure what you are getting at? the soundblaster is an internal sound card, and i get the crackles even when the controller is taken out of the equation. so just using the vdj software with the internal sound card causes the problem.
i dont get the crackling when i use the behringer ASIO driver though, in fact everything is working perfectly up until the moment it freezes!
geposted Wed 24 Oct 07 @ 12:50 am
So have you selected "auto" for the latency on the perfomances pannel of VirtualDJ ?
I advise you to download and test the sofware called : DPC Latency Checker v1.1.0
http://www.thesycon.de/eng/free_download.shtml
geposted Wed 24 Oct 07 @ 1:31 am
yeah its set to auto.
result of that ssoftware:
'This machine should be able to handle real-time streaming of audio and/or video data without drop-outs.'
highest of 120 micro seconds and average around 20 micro seconds
geposted Wed 24 Oct 07 @ 7:57 pm
