hi everybody,
during my beat mixing when I play with mid,treble and bass I hear some noises. I couldn't solve this problem.
I did format my windows, redownload version(many vesions to try) but didn't work.please help what can be the problem?
geposted Fri 09 Nov 07 @ 9:45 am
like a crackling sound when you move the eq knobs or faders? i have this problem also and its driving me insane! only seems to happen when 2 tracks are playing at once. using the ASIO driver of my behringer bcd3000 solves the problem but the driver is nowhere near as stable as using hardware soundcard.
at first i though it was a hardware conflict as i had my GFX card and USB controllers on teh same IRQ number. but i rectified the IRQ conflict and still i get the crackling.
geposted Fri 09 Nov 07 @ 2:04 pm
Try turning on safe mode, if it is already on try turning it off.
geposted Sat 10 Nov 07 @ 12:28 am
andirir wrote :
hi everybody,
hello what version do you use ?
what is your system spec?
geposted Sat 10 Nov 07 @ 12:40 am
T2050 @ 1.60 GHZ
800 MHZ, 512 RAM
tried many versions , at last PRo v5.0 R5
thx for attending
800 MHZ, 512 RAM
thx for attending
geposted Sat 10 Nov 07 @ 8:58 am
and I also have bdc2000..
geposted Sat 10 Nov 07 @ 8:59 am
Please add your serial to your profile if you are using full pro ,
or redownload the latest demo , just for information unoffical releases wont work well with it ,
i suggest you aslo investigate irq conflicts
http://www.helpwithpcs.com/upgrading/change-irq-settings.htm
as this is a common problem with bcd units
geposted Sat 10 Nov 07 @ 4:46 pm
isolate the problem first before doing drastic things like manually setting irqs. crank you latency setting up high first. i have no experience with the hardware you speak of and skyfxl will surely know from experience where to look, but my suggestion is to see if your latency is too low first before anything else
geposted Fri 16 Nov 07 @ 6:45 am
I Think you have the ground loop problem , I had the same probleem too
I solved this by disconnecting the ground wire to my computer(nobody will recommend this)
for a desktop pc it is dangerous , for a laptop ,it shouldn't be a problem
you can try connecting the whole thing through an electric extension cord without a ground connected
geposted Fri 16 Nov 07 @ 8:49 pm
