WHAT I MEANT WAS CAN I USE NUMARKS VIRTUAL VINYLS TIMECODED VINYLS WITH VIRTUAL DJ SOFTWARE USING HERCULES MK2????????????????????????????????????????????????????????
geposted Tue 13 Nov 07 @ 11:42 pm
yes , you have an answer please dont double post :)
geposted Tue 13 Nov 07 @ 11:49 pm
YES SORRY, BUT I WASNT CLARIFIED ON MY AWNSER ID THAT A YES I CAN OR NO I CANT? PLZ REPLY
geposted Tue 13 Nov 07 @ 11:51 pm
yes you can
geposted Tue 13 Nov 07 @ 11:54 pm
HI THANX ALOT FOR UR REPLY APPRECIATE IT. COULD U PLEASE EXPLAIN TO ME HOW I WOULD SET THIS UP AND HOW TO GET IT TO WORK THAN. WITH HERCULES MK2, VDJ PRO AND NUMARK VV x2.
geposted Tue 13 Nov 07 @ 11:59 pm
Skyfxl has done a TCV setup with the herc in one of his blogs, so check out the blog section, there is a diagram with it aswell.
But to use the TCV you will have to purchase VDJ pro ( if you have it please update your profile) as the home version does not support TVC.
Jimmy b
Jimmy b
geposted Wed 14 Nov 07 @ 12:27 am
THANX, YES I SHALL UPDATE MY PRO VERSION SERIAL NUMBER ONCE IV FOUND IT. SO LAZY. ANY WAYS I WAS SAYIN THAT I HAVNT GOT VDJ TCV I HAV VDJ PRO BUT IM GOING TO BUY NUMARK VV TCV SO WAS WONDERING IF THEY WOULD WORK WITH VDJ?
geposted Wed 14 Nov 07 @ 12:32 am
Yes they will. They are the same.
Jimmy b
geposted Wed 14 Nov 07 @ 1:22 am
THANKS JIMMY
geposted Wed 14 Nov 07 @ 1:26 am
