1) The PFL Knob adjusts headphone volume instead of headphone mix.
2) The pitch sliders direction is reversed. Up increases pitch instead of decreasing it, and down decreases pitch instead of increasing it.
Hope these fixes make it into the next update :-)
Thanks
Shehryar
Thanks
Shehryar
geposted Sat 17 Nov 07 @ 1:55 am
Have you tried with the new mapper available in the Tools section?
SBDJ Xponent Mapper v0.10
geposted Sat 17 Nov 07 @ 2:34 pm
I tried using the mapper, but for some reason it doesn't seem to work on my system. I tried contacting SBDJ but got no reply. I used process monitor form the sysinternals site to make sure the mapper dll was loading correctly. It returns a result code of SUCCESS when it is loaded, but I still get the default mapping. Any ideas? Thanks in advance for any help you can provide.
-Shehryar
geposted Sun 25 Nov 07 @ 6:07 am
I replied in the thread you posted as someone else had the same issue...
geposted Sun 25 Nov 07 @ 9:44 pm
