Hi again ^^
Not sure if this is in the right place, hope I haven't amde a mistake n_n"
Anyways, I've been looking for sound cards and that kind of gadget to eventually be able to have a headseat for when I am mixing, which would prove really useful, and I found this thing :
http://tinyurl.com/2y45px
It's a Hercules Muse Pocket LT USB, basically a USB thing that allows 5 different entries for sound systems.
Will it work properly ?
Has anyone got it/tested it ?
Thanks for any reply =]
~Ephem
~Ephem
geposted Fri 23 Nov 07 @ 6:42 pm
I hadn't seen that soundcard before, so don't know if supports mode 4.1 for regular mixing.
geposted Fri 23 Nov 07 @ 9:10 pm
Well it says it goes up to 5.1
And is it basically a stereo spliter ? Which is in the Config of Virtual Dj.
geposted Sat 24 Nov 07 @ 5:49 pm
virtual dj has a mode called 4.1 in which you can use only 1 soundcard and use 2 outputs if the card supports it, a soundblaster live 24 bits works just fine.
geposted Sat 24 Nov 07 @ 6:28 pm
Well I'll try and buy that one then,
µThanks for your help ^^
*edit* : Is it this one ?
http://www.amazon.fr/CREATIVE-Sound-Blaster-24-bit-External/dp/B0009N8OJW
geposted Sun 25 Nov 07 @ 12:13 pm
I have that card and it will work. I dont use it as I have an MK2. Maybe I will play around with it later today and see how well it works.
geposted Sun 25 Nov 07 @ 11:54 pm
Any sound card of my blog is compatible with Virtual DJ http://www.virtualdj.com/blog/cioce/blog4688.html
geposted Mon 26 Nov 07 @ 11:36 am
Hey again !
I jhave that sound card now and so far it's working, can anyone tell me how to configure VDJ to use a Headseat and the sound system.
geposted Wed 26 Dec 07 @ 7:13 am
Bump
geposted Thu 27 Dec 07 @ 2:59 am
