ok i have had the u46dj for quite a while.
its has had this issue for sometime now and i just played thru it.
for some reason sometime i get waht sounds like pops and static and you hear it mainly on bass kicks.
i played thru it for a while and it will come and go. now it seems to be hppening more and more.
it has done it with and without tcv.
i think it could have something to do with the laptop i am currently using possibly something with the usb port.
i can play for hours and it wont do it then next time i turn it on it starts right off. but if i close and re open vdj it stops temporarily.
if anyone knows what this could be or has had the same issue please get back to me.
i would try on another pc but cant until i get the new one built.
gauge
gauge
geposted Sat 24 Nov 07 @ 1:48 am
Try Safe Mode and Overclock if they are checked uncheck them if they are unchecked try checkin them.
geposted Sat 24 Nov 07 @ 7:33 pm
try to dissable your wifi and bluetooth ,
aslo
have you made any recent hardware changes?
you should check that your hardware is not conflicting with the u46
common offenders are wifi , video or the onboard sound
you can learn about checking for conflicts here
http://www.helpwithpcs.com/upgrading/change-irq-settings.htm
aslo
geposted Sat 24 Nov 07 @ 7:56 pm
k i am gonna try it out in a bit and i will let you guys know what happens
geposted Sun 25 Nov 07 @ 3:42 pm
ok so i tried the safe mode thing... it will play fine then when it starts getting staticy i can click or un click safe mode then hit ok and it will fix the problem temporarilly then start up again. i thought it was a power issue b4 and bought an ac adapter for the u46 and it didnt fix it... i tried plugging in my webcam as well as my u46 today got a bandwidth error... could that be the problem when only the u 46 is hooked up? all i know is it had me about to throw the u46 across the room
i tried over clock too... no affect
geposted Sun 25 Nov 07 @ 11:51 pm
this is no real solution... but when it happens to me i quickly open the u46dj console and change the buffer number to something other than its current setting (the option with 2,3,4 as options) (and i'm running .18 drivers)
i dont know what causes the problem, have checked all my IRQ things and all checks out. it happens randomly some nights... not some other nights. but even it happens...usually only once or twice a night and with that, it goes away in like 2 seconds if you can pick it up quickly.
kedar
kedar
geposted Mon 26 Nov 07 @ 11:35 am
what are you ayatem specs... it never did it my old desktop that was more powerful than this lappie
geposted Mon 26 Nov 07 @ 2:57 pm
i'm running 2 gigs of ram on a 2.1GHZ dual core processor with windows XP ... ati radeon graphics card... whjatever came upgraded from dell. decent system.... it only does that little glitch once a night usually
geposted Tue 27 Nov 07 @ 7:23 am
huh... mine does it constantly.. have yet to try it on new desktiop
geposted Tue 27 Nov 07 @ 8:47 am
try unsettings it as the default sound card for windows sounds (in control panel)
geposted Tue 27 Nov 07 @ 12:15 pm
