i know the software that comes with virtual vinyl is called CUE and it essentially virtual dj I assume virtual dj developed it for them
if not the then are biting from you guys :)
my question is
instead of cue, can i just use my standard virtual dj in conjunction with virtual vinyl?
i say this because i have all my cue points and such stored with virtual dj and it would be a pain to set them all over using cue
please answer this important question
thank you so much
my question is
thank you so much
geposted Sun 09 Dec 07 @ 2:40 am
Yes you can use the Virtual Vinyl TCV with VDJ if that is what you are askin they are the same thing:)
geposted Sun 09 Dec 07 @ 3:11 am
What I think he's asking is, will the cue points he set in VDJ translate into VV?.
geposted Sun 09 Dec 07 @ 12:53 pm
He is asking if he can simply buy the VV TCV and use them with VDJ so he doesnt lose his cues and such and the answer is yes.
geposted Sun 09 Dec 07 @ 4:29 pm
yes all three of you have summed up my answer
you all have added th epoints i was thinking of.
you do not know ho wmuch this helps
thank you so much!!
thank you so much!!
geposted Sun 09 Dec 07 @ 11:19 pm
Glad we could help.
geposted Mon 10 Dec 07 @ 1:31 am
