Is VDJ fully compatible with Vista and/or XP 64-bit OS? I will be doing a full system rebuild soon, and I am weighing options. Are there any performance differences in VDJ between running 32-bit and 64-bit OS's?
geposted Fri 14 Dec 07 @ 12:18 am
You will find that not to many drivers are available for the 64 bit os which will cause u issues. I would buy the upgrade 32 bit, install it as a clean which will install the "demo" dont enter your license key the 1st time, then put the disc in and "Upgrade" the demo and enter your key, BAM you have a fresh clean install of Vista at the price of the upgrade.
geposted Fri 14 Dec 07 @ 2:55 pm
