Forum: Old versions
Topic: Noise while crossfading, or using the eq....
I just finished a mix and I heard this crazy noise, on my playback. When I'm cueing a song and using the crossfader or even using the jog dial to set a cue I here this wierd noise. Doesn't do it all the time but it just screwed up my mix tape. It sound like rubbing on a balloon.
Any suggestions?
daflo
geposted Sat 15 Dec 07 @ 12:34 am
Set your performance slider to Fastest and if Safe Mode is checked Uncheck it if it isnt checked try checking it.
geposted Sat 15 Dec 07 @ 11:50 am
