If you preview a song (right click-> preview) and then while the preview is playing adjust the phones level or the phones mix on a Numark Total Control then this makes the preview playback stutter.
geposted Wed 02 Jan 08 @ 4:19 am
Is it with the option "safe mode" ON ?
geposted Thu 03 Jan 08 @ 2:39 pm
Yes, safe mode is on.
Actually testing it a bit further I have three more pieces of information:
1) It happens both with the on-screen controls as well as the Total Control mirrors
2) If you disconnect Total Control and just use the on-screen I have the same problem
3) The playback slider in the little preview window actually jumps foward when you move the controls (so its not just an audio problem it actually seems to change the playback point in the track)
geposted Thu 03 Jan 08 @ 3:21 pm
So now try without the "safe mode"
geposted Thu 03 Jan 08 @ 6:23 pm
Yes with Safe Mode off it seems to work OK.
geposted Fri 04 Jan 08 @ 1:02 pm
