Forum: Old versions
Topic: Song Load - Page: 2
discjockeydoc - thats a great post - makes a lot of sense - surprised I havent heard that tip before, particularly if you switch between internal and external HDD
Anyone know how to do this with vista ?
Sorry, I have no idea...I have never used Vista :(
Also keep in mind that VDJ loads the entire file into memory, if its a big one, you may run out of memory.
What happens if you try playing past the poit where the music has finished loading!?
in vista, right click on my computer icon and goto Manage. in the manage snapin, find the device manager. the usb root hub should be in the Universal Serial Bus controllers tree. Just right click on any of the Root Hub entries and goto the Power Management tab.
Hello...
I have the same problem by long tracks, so 80 minutes...
Sometimes they run fine, but sometimes they are first showed with 78 minutes and suddenly only 36 minutes....
When the long track will leave at 80 minutes, the waveform display will never show the hole track, only 3/4 of that, the rest is empty (i mean the songposition...)
Its a bug i mean...
Greetz
Avaco
