Slt tout le monde !
Vlà une bonne nouvelle en direct du site d'Hercules,je vous présente la DJ Console RMX !
Description
Cutting-edge DJ controller with built-in audio for live and studio use
Audio built for DJing
* Mic input for talk-over
* Headphone output
* 2 stereo outputs
o 4 x ¼" jack mono out (+4dBu) for pro gear
o 4 RCA mono out (-10dBv) for standard gear
* 2 stereo inputs
o Plug & mix external sources with MP3s
Metal casing
* Aluminum plate on top
* Metal sheet on bottom
Comfortable controls
* 35x25cm / 13.8"x10.7"
* Comfortable mixing
* Space for your fingers
Caractéristiques techniques
Precise jog wheels and faders for mixing
2 JOG WHEELS
* Functions
o Emulate vinyl turntables so that turning the jog wheel moves the cursor backward or forward within music tracks to select the cue point where playback will start for the audience.
o Add effects to music playback such as instant speed up, instant slow down, and scratching.
* Settings
o Adjustable resistance: makes the jog wheels more or less resistant, according to the DJ’s preference.
o Adjustable accuracy: mix with jog wheels set at their default accuracy, or divide it by 2 or 4.
* Use with
o Scratch On/Off button: changes the jog wheels’ function
o
+ Fine tuning: slow down or speed up playback, like when a DJ gives a record a push.
o
+ Scratching: makes a scratch sound, like when a DJ puts his hand on a record during playback (stopping the record’s rotation) and moves it backward and forward.
6 FADERS (SLIDERS)
* 1 Cross fader
o DJ Console Rmx plays 1 stereo music track per deck (2 stereo music tracks simultaneously). The cross fader moves between the left and right decks, allowing the DJ to adjust the mix between the 2 tracks.
o
+ Setting the cross fader completely to the right means that the mix (the music the audience hears) comes 100% from the right deck: the audience doesn’t hear the music played on the left deck.
o
+ Setting the cross fader in the center means that the music comes 50% from the left deck and 50% from the right, and so on.
o Adjustable cross fader curve: the DJ Console Rmx control panel menu lets the DJ set the cross fader curve.
o
+ Linear curve: when the cross fader is set at 25% away from its left end, the mix is 75% of the music played on the left deck and 25% of the music played on the right deck.
o
+ Bell curve: when the cross fader is set at 25% away from its left end, the mix is 60% of the music played on the left deck and 40% of the music played on the right deck.
o
+ Short curve: when the cross fader is set at 25% away from its left end, the mix is 50% of the music played on the left deck and 50% of the music played on the right deck.
o
+ The cross fader curve used depends on the DJ’s style of mixing (linear or bell curves are good for smooth transitions, while a short curve is good for sharp transitions).
* 2 Pitch faders
o Change the pitch = change the playback speed of a track, increasing or reducing its BPM (Beats Per Minute) rate, in order to make dancing easy by setting new music tracks at the same BPM as the previous track so that dancers don’t need to change their rhythm during the transition from one track to another.
o Changing the pitch changes the music’s speed and tone: faster means higher tone, slower means lower tone. The DJ can keep the same tone by enabling the master tempo effect before changing the pitch so that the pitch slider only changes the tempo instead of the pitch.
* 3 Volume faders
o "Deck A volume fader" controls the volume of the music played on deck A.
o "Deck B volume fader" controls the volume of the music played on deck B.
o "Main volume fader" controls the master volume.
o Changing the volume on deck A or deck B lets the DJ adjust transitions between the 2 decks.
Rotary controls for adjusting audio
EQUALIZATION
* 6 rotary equalization potentiometers (3 per deck: Bass, Medium, and Treble)
o Add color to your music with customs settings:
o
+ Make dancing easier by enhancing the bass (the bass provides the tempo for dancing).
o
+ Remix songs by boosting the mids (the mids contain the singer’s voice) on 1 track and mixing it with another track on the other deck, where you’ve cut the mids.
o Make transitions between 2 music tracks using bass:
o
+ Synchronize the 2 tracks: move the pitch fader to set both tracks at the same BPM.
o
+ Cut off the mids and treble on both decks, keeping only the beat of the bass.
o
+ Move the cross fader from the first deck to the second, while restoring the mids and treble.
* 6 kill buttons (3 per deck: Bass, Medium, and Treble)
o Push the buttons to cut off or restore the frequency band.
o This is a faster way to cut off or restore a frequency band than using the rotary potentiometers.
GAIN
* 2 rotary gain potentiometers (1 per deck)
o Increase or decrease the level of the tracks on each deck to put the track played on left deck at the same volume as the track played on the right deck, even if they were recorded at different levels. Gain lets the DJ compensate for different levels between tracks so that the volume is the same on both tracks when the volume faders for both tracks are set to the maximum levels.
o When the DJ connects external sources to Deck A (left deck) or B (right deck), setting the gain makes it possible to compensate for differences in volume between external sources and computer audio files.
BALANCE
* 1 rotary balance potentiometer
o Sets the balance of the main output (1-2) between the left and the right channels.
HEADPHONE CONTROLS
* 1 rotary Monitor Select potentiometer
o The Monitor Select potentiometer lets the DJ select the music played on the headphone output, either:
o
+ Previewing (the track selected with the Cue Select buttons), or Deck A + Deck B,
o
+ Or a mix of the 2 tracks, when the Monitor Select position is between these 2 settings.
* 2 Cue Select buttons (1 per deck)
o Selects the deck the DJ previews on the headphones: Cue Select Deck A or Cue Select Deck B.
* 1 rotary Headphone volume potentiometer
o Sets the volume on the headphone output, whether the headphones are plugged into the top or front panel of the controller.
MICROPHONE CONTROLS
* 1 rotary Microphone volume potentiometer
o Sets the volume of the microphone input.
* 1 Microphone On/Off button, with talk-over control
o Enables/mutes the microphone, and simultaneously attenuates/restores the background music level.
DJ buttons for instant DJing controls
BROWSER PUSH BUTTONS
* 4 buttons for browsing within music libraries (Up, Down, Left, Right)
o Up/down buttons: move to the previous (Up) or next (Down) music file/directory.
o Left/right buttons: switch the root directory (Left) or enter a directory (Right).
* 2 load buttons (Load Deck A, Load Deck B)
o Load the highlighted music track on the left deck (Load Deck A) or the right deck (Load Deck B).
SOURCE BUTTONS
* 2 buttons: Source 1 and Source 2
o Replace the computer track played on Deck A with the audio source connected to inputs 1-2 when you push the "Source 1" button. Return to the computer track when you push the "Source 1" button again.
o Replace the computer track played on Deck B with the audio source connected to inputs 3-4 when you push the "Source 2" button. Return to the computer track when you push the "Source 2" button again.
* Enabling an external audio source requires adjusting the gain control for the deck in question.
PITCH SETTINGS
* 6 buttons (3 per deck) in addition to the pitch faders
* Pitch Reset (1 button per deck):
o Gradually resets the pitch of the music to the original pitch, whatever the pitch fader position.
* Beat Lock (1 button per deck)
o In VirtualDJ 5 DJC Edition, this button switches the Master Tempo on/off. Master Tempo locks the music to its current tone, allowing the DJ to change the tempo without changing the tone.
* Sync (1 button per deck) = Synchronization
o Pushing the Sync button on a deck adjusts the speed (BPM) of the music played on the deck to the same speed (BPM) as the music played on the other deck.
PLAY/PAUSE, CUE AND STOP
o Play starts the music playback, pause stops it at its current position in the track.
o Cue places a cue point (a marker where playback should start) at the current position in the track.
o Stop halts playback and places the cursor at the Cue point.
BACKWARD/FORWARD
* 4 buttons (2 per deck)
o Quickly move the cursor within music tracks.
EFFECTS AND LOOPS: BUTTONS 1 TO 6
* 12 buttons (6 per deck)
o Loop In/Loop Out buttons (Buttons 1 and 4): Loop In button places a marker at the start point of a loop, Loop Out button sets the end point of a loop.
o Buttons 2, 3, 5, 6: special effects buttons to apply effects such as Flanger, Beat-grid, Flipping Double and Reverse to music tracks.
Audio interface tailored for DJing
4 AUDIO INPUTS
* 2 stereo audio inputs: 2 pairs of dual RCA connectors
o The DJ can replace the computer audio track played on deck A with the music played on inputs 1-2, and replace the audio track on deck B with the music played on inputs 3-4.
o With these 2 stereo inputs, Hercules DJ Console Rmx provides hybrid mixing: the DJ mixes computer audio tracks on 1 deck with the analog audio source on the other deck.
o The DJ can equalize the external audio source or set its volume as with a computer audio track.
* 2 Phono/Line switches with a ground for each phono input
* The DJ can set the preamp level for each stereo input to line (CD/MP3 player) or phono (turntable) level.
o In addition to mixing analog vinyl records, the phono/line level lets the DJ mix time-coded vinyl/CDs.
* Use in conjunction with 2 Source buttons (1 per deck)
* These buttons enable/disable the audio inputs, replacing the computer audio track on each deck.
* Use in conjunction with 2 gain potentiometers (1 per deck)
o The DJ can adjust the level of the external source to match the level of computer audio playback.
4 AUDIO OUTPUTS
* 4 x ¼" jack mono connectors (Outputs 1, 2, 3, 4)
o Play the mix at +4dBu on outputs 1-2 and the preview on outputs 3-4 with VirtualDJ 5 DJC to connect DJ Console Rmx to a PA system.
* 4 RCA connectors (Outputs 1, 2, 3, 4)
o Play the mix at -10dBv on outputs 1-2 and the preview on outputs 3-4 with VirtualDJ 5 DJC to connect DJ Console Rmx to a hi-fi system.
o Connect the ¼" jack outputs to a PA system to play the mix for the audience while simultaneously connecting the RCA outputs to the audio line input on another computer to broadcast the mix online.
o Play Deck A on outputs 1-2 and Deck B on outputs 3-4 (with VirtualDJ 5 Pro or another application) and export the mix to an external mixer.
HEADPHONE OUTPUT
* 1 headphone output (2 stereo ¼" jack plugs, located on the top and front panels of the controller)
o Preview music on your headphones.
o Set the headphone volume using the volume potentiometer located on the top panel.
o Made for DJ headphones (stereo, impedance from 16 to 64 Ohms).
MICROPHONE INPUT
* 1 microphone input (2 mono ¼" jack plugs, located on the top and front panels of the controller)
o Talk over the music (mix the microphone input with audio outputs 1-2)
o Use the microphone as a music track: replace the music on Deck A with the microphone input.
Configuration Minimum
PC minimum requirements
* 1GHz CPU or higher / 512MB RAM
* MS Windows® XP / Vista® 32-bit
Mac minimum requirements
* 1.5GHz CPU or higher / 512MB RAM
* Mac OS® 10.4 / 10.5
MoShI - JumpY
Description
* Headphone output
* 2 stereo outputs
* 2 stereo inputs
Metal casing
2 JOG WHEELS
* Functions
* Settings
* Use with
o
o
6 FADERS (SLIDERS)
* 1 Cross fader
o
o
o
o
o
o
* 2 Pitch faders
* 3 Volume faders
EQUALIZATION
o
o
o
o
o
GAIN
BALANCE
HEADPHONE CONTROLS
o
o
MICROPHONE CONTROLS
SOURCE BUTTONS
PITCH SETTINGS
BACKWARD/FORWARD
4 AUDIO INPUTS
4 AUDIO OUTPUTS
HEADPHONE OUTPUT
MICROPHONE INPUT
MoShI - JumpY
geposted Fri 18 Jan 08 @ 2:26 pm
que de news en ce moment, la nouvelle hercules, la nouvelle numark , les nouvelles pioneer,
le mixage numerique pour tous , en avant
DJ Julien
DJ Julien
geposted Fri 18 Jan 08 @ 2:33 pm
2008 commence fort !!!!,pour hercules dispo au mois de mars mais pas de tarif annoncé ,chez pioneer c'est au mois de juin au tarif de 1200 a 2200 Usd, pour numark c'est du gros aussi !!! http://www.numark.com/ns7
esperont que la compatibilité sera au rendez vous
geposted Fri 18 Jan 08 @ 2:51 pm
Et bien sûr pour ceux qu'ils ne l'ont pas encore vu:
Quote :
Hercules DJ Console Rmx est livrée avec VirtualDJ® 5 DJC Edition, référence dans le DJing sur PC et désormais aussi sur Mac. Ce Logiciel fonctionne immédiatement avec la console. Il intègre des fonctions et des réglages propres à Hercules DJ Console Rmx. L’ergonomie de la nouvelle solution Djing d’Hercules s’allie ainsi parfaitement à la puissance du moteur de mix de VirtualDJ.
geposted Fri 18 Jan 08 @ 3:14 pm
Merci pour l'info DjCel , c'est vrai que cette Hdjc RMX a premiere vu a pris un air beaucoup plus "PRO" ce qui a souvent été reproché a ces predecesseurs ,et en plus livré avec VDJ ,ca devrait le faire !! reste a savoir le tarif...
geposted Fri 18 Jan 08 @ 3:22 pm
Quote :
au prix public conseillé de 349,90 € TTC
http://www.hercules.com/fr/news/bdd/news/17/titre/hercules-dj-console-rmx-la-nouvelle-solution-professionnelle
geposted Fri 18 Jan 08 @ 3:26 pm
moi je pense que vait commence a economise des maintenant
geposted Fri 18 Jan 08 @ 3:31 pm
et ben je constate que la concurrence est très rude en ce 2008
Et a ce prix la on a meme le sac de transport , sympa hercules , a bientot pour le test
geposted Fri 18 Jan 08 @ 3:38 pm
vraiment impressionnant le nombre de controleur en se moment !!
je crois que ma petit mk2 va vite allez faire dodo dans son carton !!
au nivau ce nouveau hardware , est ce qu'il sera possible de l'avoir sans version de vdj pour les possesseurs d'une version pro avec un prix inferieur je pense ?
geposted Fri 18 Jan 08 @ 4:25 pm
Bah nan dans la mesure ou la version livrée avec les contrôleurs sont offertes !
geposted Fri 18 Jan 08 @ 4:31 pm
Justan wrote :
si, une info sur le tarif environ 350 Euros
http://www.matbe.com/actualites/28571/hercules-dj-console-rmx/
DJCel avait déjà fais la remarque XD Lol
Faut être plus rapide les gars ;)
geposted Fri 18 Jan 08 @ 4:33 pm
ok merci moshi
bon pour ne pas vous laissez avec trop de choix : je vous propose de voir aussi les nouveaux controleur vestax!!
le vcm 100 : avec faders rotatifs !!!! une premiere en harware dj je pense !
http://www.vestax.com/v/products/players/vcm-100.html
le vci 300 :
http://www.digiboy.fr/
nous sommes trop gater j'ai l'impression , merci vestax , numark , pioneer , hercules ,eks !!!
le vci 300 :
geposted Fri 18 Jan 08 @ 4:41 pm
En effet,une véritable pluie de nouveaux contrôleurs ! Qui s'est mis à la danse de la pluie que j'l'embrasse ?! :P
geposted Fri 18 Jan 08 @ 4:48 pm
Et oui en ce moment qu'est ce que ca tombe , et parlons aussi du DENON DN-HC4500 ,qui prevu en septembre 2007,apres un peu de retard et desormais disponible ,aux alentours de 500 Usd
geposted Sat 19 Jan 08 @ 5:47 am
En attendant, toujours le même regret : pas d'écran...
geposted Sat 19 Jan 08 @ 5:59 am
POUR LES PRO DE VIRTUAL DJ, j'ai deux questions qui me tracassent, car j'ai le projet de m'acheter une platine en mai...
- Y-a-til à priori une carte son dans la console comme dans la Mk2 permettant la préécoute ?!
- A priori, juste en regardant les caractéristiques, est-ce qu'elle est plus puissante que la Numark total control (plus de controleurs) ?
SINON AU NIVEAU DESIGN ELLE FAIT TRES "PRO" vous trouvez pas ??
MERCI D'AVANCE
MERCI D'AVANCE
geposted Sat 19 Jan 08 @ 7:45 am
- Oui
- Oui c'est vrai. mais est-ce que la qualité de la Total Control sera là?
- Non pas tellement à mon sens. Jolie mais pas pro.
geposted Sat 19 Jan 08 @ 8:28 am
Pour la HDJC bien sur voici une
Video du denon Hc 4500
geposted Sat 19 Jan 08 @ 9:30 am
oui la denon hc-4500 est intéressant dj cel m'avait dit qu'il y aura un mapper mais ça fait 2 mois c'est dommage car il y a plein de bug avec VDJ
c'est pour cela que j'ai choisis la DMC2 et je ne suis pas déçu
voila le commentaire de lauric
lauric wrote :
hello as tous oui j'avais confirme a limol qu'il pouvais le mettre sur le topics , mais pour l'instant je ne fait que tester la machine avec plusieur pc portable different pour voir si ce ne serait des conflit avec les portable mais pour l'instant c'est assez negatif de mon cote j'ai cru un certain moment que ca tenai le coup avec la vdj 5 v6 , mais non apparament ca plante aussi , mais je suis sur que la team vas trouver la solution
car lorsque je suis simplement en mode midi et non pas en mode denon hc 4500 dans la config du soft ca fonction tres bien , sans aucun beug , mais en config midi , il y a aucune led qu'il s'allume , mais tous le controleur fonctionnne tres bien , mais aucun affichage se fait ni aucune led , et des que je repasse en mode HC 4500 , ca plante , ce qui est fou c'est que sur le mode midi dans le soft avec le xml , la config est vraiment correct meme pour le bouton jog mode du choix de selection du jog , pour soit etres en pitchbend ou etres en scrash , il est meme attribue pour les 5 fonction key , soit c'est des point cue ou soit ca peu etres pour lance les samples , mais bon pas tres jolie ni meme cool que rien ne s'affiche ni les led , ni les titre , hors version hc 4500 , tous les affichage sont correct mais alors completement instable , en midi mode , j'ai passe ma nuit a assaye de le fair plante , et bien non il tenait bien le coup de plus ou moins 21H00 jusqu'a 5H du matin , mais je n'ai pas utilise non plus sont drivers osio car je pense que lorsqu'il utilise ses drivers et sont controle sa plante , j'utilise , une pcmcia , echo dj indigo , et la ca fonction , mais toujours sans affichage , ni led.
je vous tient au courant , de la suite . j'espere qu'il vont vite trouver une solution , car ce week end j'ai pas le choix je vais joue en mode midi et en mode aveugle , en boite en priant que ca ne plante pas , avant j'avais aucun probleme avec la hercule mk2 + echo indigo +les vinyl time code, mais bon ca le fesait pas trop surtout en etant resident d'une discotheque et en plus assez chiant de chaque foi branche et debranche tous les cable pour les platines, voila pourquoi je suis passé sur ce controleur . qui a en theorie un controle complet du soft , ben en tous cas pour le 15 min qui tient le coup c'est assez genial , car on control vraiment tous les titres defille bien assez rapide dans les reactions , mais bon completement instable , pour l'nstant je n'ai plus de new de la team , leur dernier message etais simplement comme quoi leur ingenieur travaille en colaboration avec denon, pour regler les problemes.
voila a bientot et je vous tient au courant de l'evolution
par contre sur un autre soft que je ne tient pas trop a cite de nom , en mode midi il fonction tres tres bien et les led sont reconnue , mais pas l'affichage , mais bon je n'aime pas ce soft , ca fait plus de 1,5 ans que je suis sur Virtual dj pro , et j'en suis vraiment content donc pas envie de changer .
bon j'arrete d'ecrire car je suis comme les grand mere , lorsque je commence je n'arrete plus.
Bon je le dis plus , BON MIX a TOUS , et pas oublier que :
La music est seul plaisir sensuel sans vice .
by by a tous laurent mauritz , lauric c'est mon petit garcon : et peux ce qui veulent me connaitre un peu voila
un liens www.myspace.com/xstlive ou www.youtube.com/laurentmauritz , il y a des videos de mes live et autre
bonne journee a tous et a la team .
geposted Sat 19 Jan 08 @ 9:57 am
