Hello, im trying to set up my Hercules dj mobile mp3 console. I was unable to use it wth traktor, and i remembered Vdj has an hercules option so im planning to buy it but first id like to see if this model works with the software.
This is the model i have>
http://www.amazon.co.uk/Hercules-Mobile-MP3-Wireless-Mixer/dp/B000JGWDI2
:SPOILERS: 48 hours after the buy im unable to contact Hercules for technical soport, FAQ on the support webpage dont work, user manual is not useful at all... :/SPOILERS:
geposted Thu 07 Feb 08 @ 2:43 pm
The mobile console is supported in professional edition only which you can buy online http://www.virtualdj.com/buy/ , just so you know that particular console is intended really as a toy and isnt really designed for club or mobile environments.
If you are looking for a more professional solution from Hercules you should look at the mk2 or rmx.
geposted Thu 07 Feb 08 @ 3:42 pm
Save your dollars and time... wait for the release RMX
geposted Fri 08 Feb 08 @ 1:06 pm
