Here is a link to what happaned.
http://www.virtualdj.com/forums/84980/PC_Version_Technical_Support/Crazy_crash_.html
Just got through reinstalling VDJ (up to 4.3) New external drive.
After 20 Min same thing happened again. Screen goes to a fog like effect
program locks up. Message says VDJ not responding. Wait for pgm to start or end.
Nothing happens have to wait. Sometimes it comes back & sometimes no.
I really need to get this figured out; anyone ideas please!
geposted Sat 09 Feb 08 @ 12:17 pm
What are the specs of the machine..?
I will be honest from what I read you may have issues with your machine.
And next time update your own post with this new info... don't open another thread.
geposted Sat 09 Feb 08 @ 1:18 pm
Here's the specs.
System is a Toshiba laptop Satellite A135-S4527. Intel 2080 processor.
Dual core. Windows Vista.
Sorry for updating in another thread.
If it is the machine what can I look for? This thing has never
been on the internet and is only used for VDJ.
Thinking of downgrading to windows XP.
geposted Sat 09 Feb 08 @ 1:24 pm
Have you reduced Vista to the bare essentials of processes running ? Turned off all the flare like AERO desktop? If you are considering XP, I would do go back to XP as well.
geposted Sat 09 Feb 08 @ 1:34 pm
Thanks cstoll;
I have not messed with turning anything off. (Don't really know how)
Right now I believe XP would work better.
Just want to get through Sunday if possible.
geposted Sat 09 Feb 08 @ 1:38 pm
i would almost put it on the net and get all the updates including direct x and your graphics drivers.
geposted Sat 09 Feb 08 @ 2:15 pm
