Forum: VirtualDJ Plugins
Topic: CROP plugin please?
can you please inform me if there's a crop plugin i can use?
for cut the clip up and down...
thanks!
geposted Sun 10 Feb 08 @ 11:38 am
sbangsPRO InfinityMember since 2004
Virtual DJ is a mixing program not a audio editor , if you need that sort of functionality check out Audacity or Numark Mix-vibes or a studio application.
geposted Sun 10 Feb 08 @ 12:24 pm
no no...
what i ment is cropping the video clip (cut maybe?) with a plugin from the top and bottom of the video clip so there will be a black color or something...
not for audio...
geposted Sun 10 Feb 08 @ 2:06 pm
taylaPRO InfinityMember since 2007
talm
dont think you can get that function for video, know you can use it in show logo however
Tayla
geposted Mon 11 Feb 08 @ 6:55 am
hi Tayla,
i saw there's a video plugin for resizing the clip. isn't there a one that cuts only from top and bottom?
geposted Mon 11 Feb 08 @ 7:20 am
talm1977 wrote :
hi Tayla,
You need a video editor to that trick easily.
geposted Mon 11 Feb 08 @ 1:36 pm
yes but i want to do it in REALTIME as an effect...
geposted Tue 12 Feb 08 @ 1:20 am
talm
sorry i was mistaken its not show logo i should have said back drop, anyway the only plugin i can find that comes near to what you want is cinemascope which pulls in the picture top and bottom at the same time while the video is playing
you find it as usual in plugin > video effects, hope that helps
Tayla
geposted Tue 12 Feb 08 @ 7:43 am
