can someone tell me how if i buy the two time coded vinyls from the website when i select the time coded option in my mk2 soundcard configuration it will just work with nothing else to buy is that right
geposted Tue 12 Feb 08 @ 9:13 am
When you buy the vinyls, you will not have to buy anything else, as the Herc mk2 will act as your soundcard, you should be good to go ( as long as you got some decks to play the vinyls on...hehe ).
Hope this helps.
Jimmy b
Hope this helps.
Jimmy b
geposted Tue 12 Feb 08 @ 9:42 am
That will be fine however , you may find the default asio driver for the mk2 is very laggy you may want to try using asio 4 all .
http://www.virtualdj.com/forums/68291/Hardware_Technical_Support/Some_general_info_about_Hercules_DJ_Console_MK2.html
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
For setup infomation.
geposted Wed 13 Feb 08 @ 4:23 am
