Hi,
1. Just upgraded tothe Rev7 from rev 6 andstill i notice crackling sounds from VV.
2. The cue point does not start where it is supposed to start it somethimes jumps several beats.
This was not a problem in the rev 5.
My Specs:
Windows Vista
Intel Core2Duo 2.2Ghz centrino
2 gigs of ram
Nvidia GeForce 8600M-GT 512MB
Numark Virtual Vinyl soundcard
Anyone that can solve this?, getting sick of this..
Or where can i download the previous versions?
Thanks in advance
My Specs:
Windows Vista
2 gigs of ram
Thanks in advance
geposted Sat 16 Feb 08 @ 12:45 pm
If you want rev 6
contact support.
contact support.
geposted Sat 16 Feb 08 @ 1:18 pm
If you use Numark Cue you must contact Numark for previous versions.
geposted Sun 17 Feb 08 @ 6:13 am
Oops my bad :)
geposted Sun 17 Feb 08 @ 5:19 pm
I just finished debugging a problem where VDJ starting clicking, crackling and popping during any mouse move. It had something to do with the video driver, because if I changed video settings (and then changed back) the problem went away (but VDJ would sometimes freeze on exit when I did that).
Reducing video performance one step fixed the problem. From Windows: Display Properties|Advanced|Troubleshooting.
geposted Wed 27 Feb 08 @ 6:41 am
That could be caused by an IRQ conflict with the usb port where your mouse is plugged in and the video driver. I have seen this before, try usin your mouse on a different port.
geposted Thu 28 Feb 08 @ 1:39 pm
finnhu wrote :
Hi,
My Specs:
Windows Vista
2 gigs of ram
Thanks in advance
My Specs:
Windows Vista
2 gigs of ram
Thanks in advance
Please go to Config , performances
Set latency to auto please this is important as the VV box works at the lowest possible latency at all times.
and as suggested you may want to check for conflicts using this link , http://www.helpwithpcs.com/upgrading/change-irq-settings.htm
geposted Thu 28 Feb 08 @ 3:28 pm
Hey,
Thanx, will try it out tonight
,,Finn
,,Finn
geposted Sat 01 Mar 08 @ 1:28 pm
