Hi,
There's a bug with 5.07
Since i've installed it, I can't control my DJ Control Pad
I've upgraded controlX and there's no change
Txs 4 your answer
I'm not alone ;-) :
http://www.virtualdj.com/forums/85801/French_Forum/Gros_souci_avec_Mp3_control_et_VDJ_5_0_7.html
Txs 4 your answer
I'm not alone ;-) :
geposted Sat 23 Feb 08 @ 5:12 am
The supportdesk of Virtualdj.com will send you version 5.06, when you ask for it in their helpcenter.
I had the same problem. That problem is solved by installing the "older"version.
I have the same conf. WinXP Pro DJcontrol MP3 and pro. Is a bug in the newest version 5.07. Good Luck!!
geposted Sun 09 Mar 08 @ 10:15 am
contact support and ask for rev 6
geposted Mon 10 Mar 08 @ 4:04 am
