Hi
Got TCV with MK2, thing is it work or some time then cannot control the vdj with the TCV. But when u scratch or stop the TCV you can see the vinyl moving on the pc screen but the music keep playing and you have to use the software to stop and play.
You have to restart the vdj everytime
geposted Tue 26 Feb 08 @ 9:23 am
What version of VDJ do you use ? What kind of Timecode Vinyl ?
geposted Tue 26 Feb 08 @ 10:41 am
i download from this website and i bought tcv from vdj as well and i have a maya44 usb card. Thing it works fine for some time then stop responding
geposted Thu 28 Feb 08 @ 9:28 am
I think this is a limitation of the Demo-Version. Timecode only works for some time so you can test it and then stops working. But maybe a Teamer can confirm that.
geposted Thu 28 Feb 08 @ 2:01 pm
Oh sorry! I didn´t read that you have the mk2! So you are using the Version of VDJ that came with the MK2? Have a look here http://www.virtualdj.com/products/comparison.html
Unter the Dj Console Version you can read > "Timecoded Vinyl Support" ----> Limited
But I don´t know exactly what that means.
geposted Fri 29 Feb 08 @ 12:42 am
So you not sure if its because its a demo thats why its stops. Can any1 from developepr team confirm this plz
geposted Sat 01 Mar 08 @ 7:03 am
With the demo, the Timecode is restricted to 5 or 6 minutes.
Jimmy B
Jimmy B
geposted Sat 01 Mar 08 @ 11:06 am
