Earlier have mis posted this topic in general.
I have a problem.
Am using XP Pro SP2.
My default screen resolution is 800 x 600.
When i start VDJ Trial I get message "The skin you are trying to use has a higher resolution than yours.
There is no suggestion as to what to do. By chance i changed my resolution 1o 1024 x 768 and it started ok.
Is there any way in which i can use VDJ in my default resolution viz. 800 x 600 ?
It is a hassle to go on changing screen resolution.
Regards
Nariman
I have a problem.
Regards
Nariman
geposted Fri 29 Feb 08 @ 9:45 pm
Nope, 1024X768 is what the Default skins are set at, however I believe there are a few 800X600 skins available to download after you purchase and become a Pro User:)
geposted Sat 01 Mar 08 @ 12:45 pm
