I have had severe problems with 5.0.7 and MK2 and is now back to rev5 which works great.
Problem when running 5.0.7 is that cue listening (switch on the MK2 to Deck A or Deck B) is not working at all and channel 2 main output is low no matter using single output or headphone mode.
My MK2 is latest rev and I run XP SP3rc2. Just to let you guys know.
geposted Fri 07 Mar 08 @ 5:05 pm
Having the same problem. Where do I find that rev5 version?
geposted Fri 07 Mar 08 @ 6:36 pm
I had the same problem and reinstall VDJ, a third time and it worked. Can't get timecodes to work at all. Distortion, Distortion, Distortion, no matter what settings I use.
geposted Fri 07 Mar 08 @ 7:50 pm
With 5.0 rev 7 u cant use the mk2 icon u have to use 4.1 mode
Input: None
Output: Headphone
SC: 4.1
Do a search guys there are quite a few threads that this is talked about in.
I made a post named Attn All MK2 users with the explanation of exactly how u set it up.
HERE http://www.virtualdj.com/forums/85407/General_Discussion/Attn__All_Regarding_Mk2.html?highlight=attn
Input: None
Output: Headphone
SC: 4.1
geposted Fri 07 Mar 08 @ 8:17 pm
