Forum: VirtualDJ Skins
Topic: pitch bend in a a circle
Is it possible to pitch bend using the mouse rather that scratching ?
I have a rotate circle area in my skin and I can scratch on it when I hold the mouse down and move in the circular motion,
But i want to make a wheel that pitch bends (rather than plus/minus buttons).
I.e. when i press the mouse button the record doesnt stop and when i move the mouse clockwise/anticlockwise it makes fine pitch adjustments.
I know I can change the factor in the scratch zone but this doesn't stop the record from pausing when I press the mouse button.
Does anyone know if this is possible ?
Ultimately this will be in a pannel group so a jog button will switch between pitch bend and scratch.
Thanks very much
geposted Fri 14 Mar 08 @ 2:07 pm
Use the right click / hold on the as you say circle to gently slow or speed up as needed.
i know excactly what you mean, i would build this in my skin too, but i also didn't know how i can do that i have tried serveral things but still with no results. And i'm also curious if you can put a visual element to it, if it can what is the code for it.
i have found something like the codes, scratchwheel, wheel and wheelmode. maby this work. with wheelmode you can change between some scratch function and a cdj function. I've seen it by keybord shortcuts and than by add.
Thanks will try it !
