whats going on . i recently updated my mk2 and virtual dj to the latest versions. and i have 2 problems with them. first the headphones i can hear deck a or deck b but i can listen to the split and the mix. second thing is if i do anything like change tempo volume sync etc the sound distortes and if i use the treble med or bass nobbs it sounds like i am using a flanger ... any help? please thanks all
geposted Fri 14 Mar 08 @ 3:52 pm
do a search in the general forum for attn all mk2 users, you will find your answer there.
geposted Fri 14 Mar 08 @ 5:10 pm
Hi bedaddj, look
Here!
Brian i think this should a sticky (for a time being) as well along with updating the firmware for mk2;)
Here!
geposted Sat 15 Mar 08 @ 8:00 am
Done. In General Discussion.
geposted Sat 15 Mar 08 @ 9:19 am
Thnks;) I sure it will be able to help some user.
geposted Sat 15 Mar 08 @ 3:00 pm
Hi, I am also having this problem - can hear on A and B but not on Split / Mix.
Tried to find the sticky as previous link in this thread is dead, however, cannot find the post? It's probably me!
Cheers, Mick
Cheers, Mick
geposted Thu 17 Apr 08 @ 2:04 pm
What version are u using?
Download the latest driver from herc website. It will correct ur problem;)
geposted Thu 17 Apr 08 @ 2:13 pm
