Forum: Music discussion
Topic: Master Tempo????
mana69Home userMember since 2008
I am wondering if VDJ can control the tempo of both decks at the same time?
eg.
Deck 1 has a track with a tempo of 100bpm
In Deck 2 is a track that is 120bpm
Question: How would you mix the two in????
I would match the tempo of Deck 2 with Deck 1 dropping it down to 100bpm from 120bpm
Then i would mix in Deck 2 until Deck 1 is fully mixed out then raise the tempo in Deck 2 up to its original tempo of 120bpm
Question: When i drop Deck 2 down to 100bpms to match Deck 1 can VDJ lock the tempos of both the decks so i can raise them both up to 120bpm at the same time???
Any help would be appreciated.
Thanks in Advance!
geposted Mon 17 Mar 08 @ 11:47 pm
NRK PTHome userMember since 2008
I have the same question too
:D
but my VDJ isn`t working like in the begining. My crossfader doesn`t work and I can`t cut of the bass.
I think the SYNC button isn`t working too.
Maybe the problem is the skin.
geposted Wed 19 Mar 08 @ 5:18 am
geposted Wed 19 Mar 08 @ 11:24 am
