Hello all... i want to connect my audio usb interface numark with my djc mkII with my external mixtable,my 2 turntables(vtc) and my Pc...have you one solution or pictures for show me how i must do...
Thanks for all
Myllox
Thanks for all
Myllox
geposted Sun 23 Mar 08 @ 1:36 pm
Try this post Millo,
http://www.virtualdj.com/forums/59875/Hardware_Technical_Support/ultimate_guide_to_controllers.html?page=1
TCV setup using the mk2. Picture 3/4 of the page down.
Hope this helps.
Jimmy b
Hope this helps.
Jimmy b
geposted Sun 23 Mar 08 @ 2:18 pm
Hi , Connect your Turntables to the VV box
Then connect your amp to the output 1 of your VV box
Enable the MK2 in the controller section Config > remotes
You want to use the MK2 as the controller only as the VV box will produce a much superior sound.
geposted Sun 23 Mar 08 @ 2:47 pm
