I have 7000 karaoke tracks in my karaoke folder in my music however if i select the karaoke folder iin VDJ there are only 9 files in there, I cant remember what the recurse feature does however i did it anyway and it didn't fix it anyway! any ideas? this must be an easy one.
geposted Wed 02 Apr 08 @ 4:18 pm
Have you tried clicking on the folder, then right clicking, and add to search DB, or something like that.
Jimmy b
geposted Wed 02 Apr 08 @ 4:58 pm
I made a similar mistake and solved it by selecting show by filename in the main window instead of MP3 tags. I couldn't figure out where all the files went to. They showed back up just fine after that.
-DGee
-DGee
geposted Wed 02 Apr 08 @ 11:02 pm
Dam, it was the show karaoke that wasn't selected with the three option you now get next to the search box.
Thanks guys
Thanks guys
geposted Thu 03 Apr 08 @ 6:11 am
