Forum: VirtualDJ Plugins
Topic: I could use some help with GetInfo()
I'm writing a custom mapper and I have a little problem:
I call GetInfo to get various int values. Everything works as it should!
But if I call GetInfo to get char* values while it works fine in runtime, when I try to close the app it hungs...
Can anyone help me please?
geposted Thu 03 Apr 08 @ 4:31 pm
I've not had that problem, any chance of a sample of how you're declaring, calling and using?
Regards,
Scott
geposted Fri 04 Apr 08 @ 10:33 pm
Among other parts of code I will post only the parts that matter...
class PhantomDj : public IVdjPluginDevice
public:
char ArtistA[36]; char ArtistB[36]; char TitleA[36]; char TitleB[36];
HRESULT hrs;}
HRESULT __stdcall PhantomDj::OnTimer()
if (DeckInfo[0]->Status>0){
hrs=GetInfo("Author 1",&ArtistA);
SetText(0,DENON4500_TEXT_LINE1,ArtistA);}
ULONG __stdcall PhantomDj::Release()
return S_OK;
On the Release I also tried delete
delete this;
return 0;
With no success
As I said, it works fine during runtime.... It hangs the app when I try to exit so I believe it has something to do with the destructor...
If I don't use GetInfo to get ArtistA everything works fine... Also I don't experience any issues when I read int values ..
PS: My C++ knowledge is very limited... I'm mostly a VB programmer... I just write this mapper while I try to learn the basics on the same time....
geposted Mon 07 Apr 08 @ 4:13 am
djcelPRO InfinityModeratorMember since 2004
PhantomDeejay wrote :
char ArtistA[36];
HRESULT hrs;
use:
char ArtistA[512]="";
GetInfo("Author 1",ArtistA);
ArtistA is already a pointer
( <=> char *ArstistA=new char[512]; )
geposted Mon 07 Apr 08 @ 9:39 am
