Forum: Old versions
Topic: Low freq sound when sliding pods on Total control
When i am playing and use the knobs and slides it can be heard on the recording and throught the apeakers. The sound it is emitting is like a low freq gurgle. Only when using slider or turning. Can I talk to someone that knoow TC welk?
geposted Sun 06 Apr 08 @ 8:49 pm
Tear Em 'UpPRO InfinitySenior ModeratorMember since 2006
What soundcard are you using?? And, what are your setting in the config menu?
geposted Sun 06 Apr 08 @ 9:11 pm
Set your latency to Auto. check the safe mode, if it is checked uncheck it., if it isnt checked, check it.
geposted Sun 06 Apr 08 @ 9:12 pm
