That can't be right. Anyone getting this issue
geposted Sat 19 Apr 08 @ 7:37 am
To tell you the truth I haven't noticed. Don't really use Eq when I'm cue'ing up. On use it when I'm mixing the track
Will try it out tonight and see.
geposted Sat 19 Apr 08 @ 9:45 am
I am not trying to be a smart ass...why use EQs for cueing?? I completely understand using an EQ for the mains...but when you are just cueing up a song in my experience there is no point. In my 25+ years of DJing I have not ever seen one mixer that gave the option of EQing the headphones, unless you were reviewing the main out sorced sound.
geposted Sat 19 Apr 08 @ 9:52 am
PFD50
If you want try the Registry Tool v1.6.2 and add it.
http://www.virtualdj.com/addons/view.html?type=tool&page=2
It should work
P.S
TearEmUp
"THE Pioneer 500 or the 600, I think it was the 500"
It should work
P.S
TearEmUp
geposted Sat 19 Apr 08 @ 12:50 pm
Well,that explains it..I don't like the Pioneer mixers....
geposted Sat 19 Apr 08 @ 1:00 pm
Thanks guys.
I've always used the EQ to check out the different part of the mix
geposted Sun 20 Apr 08 @ 8:20 am
