Forum: Wishes and new features
Topic: Master tempo/Timestrech
naffieHome userMember since 2003
Is it possible to get a button next to the pitchcontrol sliders of each deck wich can toggle the timestretch/master tempo option for that deck? (Just like on a pioneer cdj1000)
geposted Thu 23 Dec 04 @ 12:19 pm
claxPRO InfinityMember since 2004
There is a skin with these buttons but I hace forgotten which one it is.
If you want you can adapt the skin you use to insert these buttons inside (with paint or another graphic soft).
You can also create a shortcut to enable/disable Time Strech.
geposted Thu 23 Dec 04 @ 12:34 pm
djcelPRO InfinityModeratorMember since 2004
Unfortunately, the time strech works for the both decks and you can't only use it for one deck.
Clax:
this is the skin I sent to you and it is only one to have this function ;-)
geposted Thu 23 Dec 04 @ 5:54 pm
