I don't know much about file formats when it comes to video.
I am looking to get a capture card and capture some video from my xbox 360 (rock band, guitar hero 3) and want to pick out a good capture card, that gives me high quality.
I was wondering what formats scratch the best, and what ones load the best, and also the quality of the sound and video is fairly important.
Thanks in advance!
Thanks in advance!
geposted Sun 04 May 08 @ 9:42 am
Raw dvd file.. ripped straight from the DVD, either as VOB or renamed as MPEG2 (same thing).
Users have also have had good experience with compressed videos, such as DivX6...
but for best quality, best performance, original is best ;) Like wave to audio (kinda)
If you need to compress for space savings on drive, choose DivX, Xvid or Mp4.
If you want to CAPTURE video, like you are saying, choose the screen resolution that you want (DVD ratio, or HDTV ratio, if you plan to show on external screens, or Windows screen size if you want to mix only on your pc... ) Capture the file as mpeg2 for best quality, or divx for compressed good quality.
geposted Sun 04 May 08 @ 11:22 am
Sounds like you're just getting into video and are wanting to scratch,
In addition to dj-in-norway's excellent and concise information - make sure your computer meets VDJ's spec's for playing video.
Follow this link and go to the bottom of the page.
http://www.virtualdj.com/products/virtualdj/index.html
Peace
Peace
geposted Sun 04 May 08 @ 5:46 pm
I own Virtual DJ home edition. My Audio/Video(VOB File) is out of Sync. What's The problem?
geposted Tue 13 May 08 @ 8:03 pm
Probally a weak video card or not enough memory or a slow processor.
geposted Tue 13 May 08 @ 8:09 pm
I have a pc with these specs:
MSI P7n Mobo
Intel Quad Q9300 cpu (2.5)
Nvidia 8800gts 512mb OC video card
4 gb ddr2-800 Corsair Dominator Ram (3gb usuable since it's XP 32-bit)
XP Home for an OS
I have tried scratching video, and nothing slows this pc down.
I'm just looking for great quality video, as well as a good inexpensive capturing and also an editing software.
MSI P7n Mobo
XP Home for an OS
geposted Wed 21 May 08 @ 10:57 pm
If you want to able to play backward or scratch you will need a codec like Picvideo MJPEG. MPG2 works, but not so suitable.
geposted Sun 01 Jun 08 @ 4:28 am
MSI P7n Mobo
XP Home for an OS
MSI P7n Mobo
XP Home for an OS
WOW nice system man!!! Off the subject a lil bit have you tried Vista on that monster??
Also agree with Norway, best is .vob (mpeg2)
geposted Sun 01 Jun 08 @ 4:34 am
I'm not sure on the best quality, but I've had fairly decent results with a winfast DTV1000 pci card. It's mainly a TV card, but it's got an S-Video input for recording. And the software has some decent presets for different video formats, so it's easy to just set it "DVD quality".
Hope that gives you a starting point at least.
geposted Sun 01 Jun 08 @ 7:20 am
