how do you set it up to switch the decks to go back and forth automatically
geposted Tue 06 May 08 @ 8:14 am
I REALLY APPRECIATE NOBODY HELPING ME... THANKS
geposted Thu 08 May 08 @ 7:10 am
dont think its a case of that rob its just the forums may not have as much activity today as usual, if i'm right in assuming you are talking about the old automix system which went the way you are describing, that was dispensed with sometime back and replaced with something far superior to it in my judgement but at a great loss to many other users, to do something with similar functions load up your songs you want to use in your play list then quite simply activate automix by highlighting the button at the top left of the playlist box it will turn greenish when activated, to end or skip into another track double click on the track you wish to bring in.
the button below that has a few functions you can use ie unload played tracks, repeat etc... hope thats helped
Tayla
Tayla
geposted Thu 08 May 08 @ 7:40 am
THANKS TAYLA... I SEEN A FRIEND OF MINE AT THE BAR USING VIRTUAL DJ THERE BUT I DONT KNOW WHAT VERSION HE HAS... BUT U HAVE 2 SONGS LOADED INTO THE TURNTABLE AREA AND AFTER ONE SONG FINISHES THE OTHER TURNTABLE STARTS AND THE NEXT SONG IS LOADED ONTO THE TURNTABLE THAT JUST FINISHED... THATS WHAT IM TRYING TO DO
geposted Fri 09 May 08 @ 7:05 am
sounds like your talking about automix?
geposted Fri 09 May 08 @ 8:24 am
yeah its what i was saying earlier rob, you are after an older version of vdj can't remember which one though, but if you follow the instructions i gave you earlier you will get the same effect but without the two spinning decks... hope that helps
geposted Fri 09 May 08 @ 8:43 am
yea i figured that part out before... i was just tryin to get both decks to work.. thanks for the help
geposted Sat 10 May 08 @ 10:32 pm
