This is a dumb question for a person who has been using VirtualDJ since 1.x but still I have to ask...
Is there a way to sort the record case so I can show just the tracks that have NOT been BPM scanned? Assume I right click on a folder with 40 sub folders, recurse. Some tracks have yellow questions mark, some do not. If they were all in the same flat folder list, this would be easy, I would just sort the list and be done. When the tracks are in sub folders, it complicates things.
I want all the un scanned tracks at the top or bottom so I can select them and let them scan overnight.
WirelessDJ
WirelessDJ
geposted Wed 07 May 08 @ 7:35 am
I am in the same boat!
Was doing this last night but its a pain.
I think the best thing to do is make another folder and move all the music there and move it back to where you want it when your done.
I hope thee is any easier way.
geposted Wed 07 May 08 @ 8:34 am
Easy, recurse the folder, then at the top, click the 'bpm' tab
Also, you can make a virtual folder that will ONLY show unscanned tracks, I could be corrected on this but I think the filter is 'isscanned=0'
geposted Wed 07 May 08 @ 9:29 am
The virtual folder is the right option, but its BPM=0 that will show all the unscanned files in your library
geposted Wed 07 May 08 @ 9:49 am
isscanned=0 is the correct filter option. And Filter folders only work with files that have been added to the Search Database.
More info is available in the manual.
geposted Wed 07 May 08 @ 11:27 am
I think there is.
I actually found this quite interesting I haven't seen anything like it.....Click on the bpm tab in the first folder...scroll to the last calculated bpm then...shift+ down arrow to the end( select all).....then do the same in the remaining folders/subfolders , click calculate whatever your engine is selected to and go to bed....when you wake up everything should be done so long as you don't have any corrupt files..Then from there do the whole database add nonsense and save the xml file and you good to go.
geposted Wed 07 May 08 @ 11:58 am
Wow, that is quite a bit of instructions. For a year now I use the isscan=0 and isscan=1.... whatever is in that folder for missed scans then just highlight and scan. In config, put add to databasa automatically.
geposted Wed 07 May 08 @ 12:22 pm
ok -- here we go ---
1. As suggested by fatkatzdj - Go to Config -> Browser -> Set Add to Database to Automatically
2. Recurse you entire music drive library (if you have multiple drives do this for each drive)
--- Upon recursing each drive, what ever track was not part of the search database will be add because of step 1
3. Create a filter folder that uses a filter of isscanned=0
4. Select the New filter folder to reveal the tracks that have yet to be scanned.
In the future when adding new tracks you only need to do steps 2 and 4.
To analyze the tracks --
Select in the center browser (left click 1 time)
Ctr+A - to select all
Right-click any highlighted track and choose the appropriate BPM Analyze method.
geposted Wed 07 May 08 @ 4:06 pm
I may be wrong, but I think this may be the quickest way;
1. Enter * (an asterisk) in the SEARCH field (this brings up ALL your tracks).
2. Click on the BPM tab (all of your un-scanned tracks will be either at the Top/Bottom)
3. Highlight all of the un-scanned tracks and Click on Analyze.
4. Go to sleep while VDJ does the analyzing.
geposted Thu 08 May 08 @ 1:34 am
Only works if all of your tracks are part of your search database.
geposted Thu 08 May 08 @ 5:44 am
and
That wont work!! I BPM my files with Mixmeister so they all have BPM'S
--> IDEA to Atomix Productions: add a playlist on the left called 'Unscanned Tracks' that shows all tracks that have not been scanned. User can click on that folder, select all, then scan.
I will muck around with isscanned=0 filter
and
geposted Thu 08 May 08 @ 7:25 am
WirelessDJ;
I don't use any other mixing program or alike, so this may ba a silly question.
I use to BPM all my tracks with Mixmeister as soon as I ripped them, but quickly figured out VDJ will re-do the BPM's whether I want it to or not.
Is there a specific reason you pre-BPM all your tracks before placing them into your VDJ database?
geposted Thu 08 May 08 @ 4:59 pm
It already exists -- it is the Filter Folder as described.
geposted Thu 08 May 08 @ 6:05 pm
Agreed. But it does not show up automatically and was not that intuitive to add. Why not consider having it as a default filter?
Yes! I own three Numark D2's. Lovely little (discontinued) units. I simply plug in a 32GB flash drive...
...and I am good to go with no bootup time, no heavy laptop to lug around, no chance of crashing. I use them as a backup when I am not using my PC rig and/or when ever I feel like traveling light
WirelessDJ UltraLight Rig 2008 - Standalone
Rane MP2S http://www.rane.com/mp2s.html
Flash Survivor 32GB by Corsair http://www.slashgear.com/gallery/data_files/2/7/8/100_4140.JPG
Numark D2 Director (2nd one in car in case of failure)
Technics RP=DH1200 headphones http://www.planetgizmo.co.uk/images/P/technics-large.jpg
Odyssey BR4 rack bag http://www.thewirelessdj.com/#/gear/4521229376
Shure SM58S http://img3.musiciansfriend.com/dbase/pics/products/regular/3/1/2/244312.jpg
So.... The D2 reads the BPM that mixmesiter writes into the tag.
I use FILE browser a lot with the D2 which is why I also rename my tags as follows... (BPM, Title - Artist)
100.00, BADD - YING YANG TWINS F. MIKE JONES.MP3
100.00, SHAKE IT (ASV REMIX) TYAJAYZE - ASV REMIX.MP3
100.04, NAUGHTY GIRL - BEYONCE.MP3
100.82, GET IT POPPIN (FUNKYMIX) - FAT JOE & NELLY.MP3
etc.
Then I just pop in and out of folders all night. Also using the search by title, artist, or BPM range
It's too bad Numark quality is inferior to Denon HC4500, this is why I have THREE of them! One for use at the club, one in the car, and one is always in the shop for repair :-(
Here is my 2nd PC based rig...
WirelessDJ UltraLight Rig 2008 - PC Based
VirtualDJ http://www.virtualdj.com/images/full_screenshot_800_03.jpg
Denon HC-4500 http://www.audioweb.nl/shop/images/uploads/Denon%20hc4500.jpg
Acer 5570Z (XP! no Vista) http://thoughtsinbinary.com/wp-content/uploads/2007/03/img_4255.JPG
OtterBox 7030 laptop case http://www.ampro.co.nz/products/otter/Laptop_case_inuse.jpg
etc.
geposted Fri 09 May 08 @ 7:20 am
@Wireless......
Where do you park your car?
geposted Fri 09 May 08 @ 8:25 am
i dl the new vesion last night and as we know my ex. hd crashed so am ripping music again
is there anyway i can scan for bpms an easier way
with the new version
geposted Wed 18 Jun 08 @ 9:23 am
lennyndegwa wrote :
@Wireless......
lol
geposted Wed 18 Jun 08 @ 5:12 pm
