Hi, first of all sorry for my english, i have seen this picture http://www.etcetera.co.uk/products/images/HER102su2.gif and my question is if i can do the same but WITHOUT the external mixer, just with mk2 2 turntables and the pc.
Thank you.
Thank you.
geposted Mon 12 May 08 @ 11:41 am
Turntables go into inputs 1/2, inputs 3/4
Output 1/2 goes to your amp/PC speakers. Quite simpy really.
geposted Mon 12 May 08 @ 11:45 am
Hi and thanks for answer so fast, excuse me becouse i am new, but i need an amp?
geposted Mon 12 May 08 @ 11:47 am
You don't have to, but the sound quality is better running though a amp, than PC speakers.
geposted Mon 12 May 08 @ 11:50 am
A lot of thanks, you really help me :)
geposted Mon 12 May 08 @ 11:51 am
No Worries mate :)
geposted Mon 12 May 08 @ 1:01 pm
Other question, I think is a bit stupid:
- from the mk2 console to the PC, how many cables are? The USB and the cable from Output 1/2 to the speakers?
geposted Tue 13 May 08 @ 8:01 am
Nope, just one USB cable connecting MK2 to the PC, all audio cables are on the MK2 itself.
geposted Tue 13 May 08 @ 10:01 am
Ok so when you want to hear the sound in a amp you need a "special cable" connecting from mk2 to amp; but when you want to hear the sound with the pc speakers, the USB is sufficient, no?
A lot of thanks.
A lot of thanks.
geposted Tue 13 May 08 @ 12:02 pm
A lot of thanks.
A lot of thanks.
mk2 (outputs 1&2) to amp, you want a RCA cable with 4 male jacks.
mk2 to PC speakers, (small output 1&2) small 3.5mm jack (the one on your speakers that go into the soundcard of your PC).
geposted Tue 13 May 08 @ 12:15 pm
Ok, now i understand
A lot of thanks
A lot of thanks
geposted Tue 13 May 08 @ 12:45 pm
MK2 + 2 numarkt tt 500s + mixer will sond good?
If it is yes what mixer do you recomend me?
Thanks.
Thanks.
geposted Thu 15 May 08 @ 10:27 am
Thanks.
Thanks.
An RMX would be better and a VV box would be even better than that.
geposted Fri 16 May 08 @ 4:03 pm
Ok, can I invert the faders of hercules rmx or of the virtual dj program?
geposted Sat 17 May 08 @ 6:49 am
You can map whatever you want as it is MIDI mixer. There is no Mapper for RMX yet, but soon.
geposted Sun 18 May 08 @ 9:52 am
