trying to use the dac 4.3 skin outside, it's to dark.. you did a skin for outside.. i want to do the same thing to the DAC skin.. that's all
geposted Tue 17 Jun 08 @ 11:53 am
Well you can start by opening up the zip, then taking the .bmp file in a graphics editor and invert the colors. It should be ok for the most part but depending on what colors were used in the 1st place additional changes then in the .xml file would be needed.
for example i made all the artist/song track times in black since the majority of the skin was now white.
try and see what happens. If you need help chaning colors just ask.
geposted Tue 17 Jun 08 @ 4:09 pm
when I go to the skin 4.3 dac & unzip it, there is no bmp or xml files, When I double click on the folders, one opens up with colors, but it's miniature size you can't really see what it is. I just get a small top to bottom image only about 2" wide and the rest of the page is white.
Is there any chance you can invert it so I can use it outside in the sunlight? (like the one you did before where the letters are in black and the background would be in white)
geposted Tue 17 Jun 08 @ 7:26 pm
Only 1 skin ? Where yo shall put more VDJ outdoor skins ?
I lke to see the preview they are just wonderfull !
geposted Thu 19 Jun 08 @ 8:50 pm
