Is there anyway i can use both timecoded vinyl and normal vinyl without having to swap leads about or anything? Maybe with a Y photo splitter cable?
Thanks
Thanks
geposted Tue 13 May 08 @ 5:47 pm
Have you tried the search feature? Also, what version are you using??
geposted Tue 13 May 08 @ 6:16 pm
I did try searching, but i could not find anything to help me. Im currently using v5.0 and my timecodes are setup and working correctly but i want to use normal vinyl aswell as timecoded without having to change anything around to do so.
geposted Tue 13 May 08 @ 8:10 pm
Yes you can Please look here.
It's talk's about TCCD, but it's a similar process for TCV.
geposted Wed 14 May 08 @ 12:43 am
also you might want to think about getting the MAudio Torq soundcard. The cool thing about the card is by simply turning the knobs to the left you get the timecode signal, by turning them to the left go can play normal wax or CD's.
geposted Wed 14 May 08 @ 10:43 am
How many turns to the left do these knobs have?
Just kidding you
geposted Wed 14 May 08 @ 11:04 am
Yes and the phono through of the conectiv suck (output volume, whats that ?) ;)
geposted Wed 14 May 08 @ 2:10 pm
