as a mobile dj I occassionally use the automix function. If I load a dozen songs from my 80's folder and then switch (via the explorer window) to my 90s folder , all the 80s songs VANISH from the automix window!!! How can I load tracks from multiple folders and have them remain in the autoplay "cue"? Dont recall this being a problem on earlier versions.
geposted Fri 16 May 08 @ 10:19 pm
Go to config>options and set "autoload playlists" to disabled.
What happens when this feature is enabled is that the playlist is cleared when you navigate away (in case you were going to your playlist folder to load one), so that it loads the intended playlist instead of adding to tracks that were left (or intentionally placed) there.
This should fix you up ;)
geposted Fri 16 May 08 @ 11:14 pm
Thanks DJ Doc, will give it a try....
geposted Fri 16 May 08 @ 11:24 pm
yep, that fixed me up.....thanks for the advise.....sorry i had a brain poop on that one
geposted Mon 07 Jul 08 @ 9:17 pm
