Hi,
When I press the forward and backward buttons on thr Herules RMX a few times, it's like they get "stuck". The deck keeps winding either forwards or backwards on the screen, even when I replace it with another mp3. This happens on both sides, for both forward and backwards, and is fine again when I restart VDJ, so I don't think it's a hardware problem.
Please help.
Thanks,
A very frustrated and disappointed DJ...
Please help.
Thanks,
geposted Sun 18 May 08 @ 3:46 pm
Do not press both buttons at the same time
geposted Sun 18 May 08 @ 5:17 pm
hehe, if you know you've got a problem doing a certain task and it's not necessary why persist in doing it, just to prove you can create a problem??? i've had problems with my rmx but you should soon realise they are more than likely user invoked, like you have demonstrated...
geposted Sun 18 May 08 @ 8:33 pm
Thanks a million djcel, that seems to be the problem all right. Seems a bit odd that this could even be allowed to happen though, pressing the two buttons at once is quite easy to do, especially in the stress of a mix. Is there any way to sort it out if it does happen, do you know(other than restarting it)?
geposted Sat 24 May 08 @ 8:15 am
