Got Vista 64 Bit Windows ultimate and can't open my VDJ software, all of which have been updated can any one help me sortthis problem please?
geposted Sat 24 May 08 @ 10:36 am
You should use 32bit OS, it is too early for 64bit systems, VDJ can work, but you must do many tweaks and new drivers for all your hardware to be able to work in 64 Vista.
That error that is you getting is regarding sound card, your drivers is not ok or you need to select it in Sound Config.
geposted Sun 25 May 08 @ 8:08 am
Thx, but already got the 64 bit version, can I switch it to 32 bit? If not do you know hw to config the 64 bit to get it to work? Do you think getting the VDJ Pro edition will make it work? Getting so frustarted with thisnew laptop, why did I get 64 bit..!
geposted Sun 25 May 08 @ 11:58 am
I know, I really don't understand why they sell 64bit OS anyway?
Post here your entire spec, PC hardware, Sound card etc.
geposted Sun 25 May 08 @ 1:13 pm
Cheers fella, I've just bought a custom build one from PCSPECIALIST it's got: Intel(R)Core(TM)2 Duo CPU T7700 @2.40Ghz 2.40 Ghz. 3GB RAM. Windows Vista Ultimate 64-bit SP1. It's got a Hi Def sound card. Is that what you need fella? Not sure where I get any further info?
geposted Sun 25 May 08 @ 3:02 pm
First of all I was getting the direct x sound driver message come up then tried all sorts and then that disappeared and the message saying no console detected, or words to that effect... now I'm back to the Direct x message! Arrr nightmare I've spent last 2 full days trying to sort this just wnat to get on with mixing!
geposted Sun 25 May 08 @ 3:12 pm
Do you use MK2 as a sound card or the one on the motherboard? For both you need 64bit drivers, which there might not be.
Do you think it is worth upgrading to VDJ Pro? Would this solve the problem? And if so I've seen a link where you can upgrade to it for a lot cheaper than the original cost in one of the blogs but can't find it anymore....
geposted Sun 25 May 08 @ 3:18 pm
Um not sure..the one in mother board should be 64 bit as that works but from understanding the one in the MK2 isn't, I have tried diabling the mother board one and opening the VDJ Software but no joy....is there any way around this?
geposted Sun 25 May 08 @ 3:20 pm
First of all have you thought about getting a OEM copy of 32bit Vista, or even downgrading to XP. XP will be dirt cheap now. And do a fresh install of the new OS.
Try reinstall the drivers for the mk2 using a different usb port and alwys use that port with the mk2, do not use any other. If you do then the mk2 will not be recognized and you may get a error message.
If you are using the version of VirtualDJ (Home version 3.4.1) that came with the mk2, the software will not open or start unless the mk2 is connected. That version is tied to the console.
The DirectX sound driver message you were getting, all that is I think, is the software has noticed a change in the sound setup from last time you opened VirtualDJ, and shows that error
I hope this helps you
geposted Sun 25 May 08 @ 3:45 pm
Cheers jimmy, I can't downgrade my software cos apparently when i spoke to the people who built it with the spec I was requesting I had to have the Vista 64 bit. So don't think I can? OK I'lltry to re install using different usb, see if that helps? I've updated the firmware also, don't know if thats made problem worse or not? Thanks
geposted Sun 25 May 08 @ 3:51 pm
WOW... I have no idea what I did but all I have done is changed the USB and put it into a different port and the software opened.... SORTED... Thanks for all advice, m look a bit stupid now... surely it was something else I did...! Thanks again...in the mix as I type....
geposted Sun 25 May 08 @ 4:18 pm
As I said in the previous post, always use that port and you will not have a problem.
I'm glad I could help, may be soon you might want to up grade pro....it's worth it
Anyway Happy Spinning.
geposted Mon 26 May 08 @ 2:59 am
Yes thanks Jimmy.. Howeer knew I spoke too soon...although it is working.. it's now jumping a lot during playback whilst in the mix.... any ideas? As cearly this isn'y any good and extremely frustrating, I'd like to think it's not the performance of the laptop as it is pretty up to date!? ... Help!
geposted Mon 26 May 08 @ 8:00 am
Have you got a Performance tab in the Home edition I can't quite remember, if you have Move the preset slider all the way to fastest and put latency on auto. If you haven't try this,
On the herc Control panel, click on the Asio mode button look at the Asio buffer level, I think it's set at 960 as default, try raising it to round about 2000-2400. I always ran in Asio mode as I found it far better the WDM mode.
Give that a try mate.
geposted Mon 26 May 08 @ 10:34 am
Jimmy You are a legend...! Seems tohave done the trick changing the ASIO settings... you can tell I'm out of touch and just getting back to it! Many thanks...
geposted Mon 26 May 08 @ 10:55 am
Nice one, and thank you kind Sir, lol. I knew all the problems you where having....................because I had the exact ones, when I first started with VirtualdDJ and the mk2 over 14 months ago :)
Asio mode it's only really for external control like running TCV or TCCD's but I found with my set up it helped everything to run sweet, don't know why but it did.
Glad it's all sorted.
geposted Mon 26 May 08 @ 11:03 am
Thanks again Jimmy, I also sent you an email to your BTInternet address just incase you hadn't seen these posts. Regars...Mat
geposted Mon 26 May 08 @ 11:21 am
It's Fine mate, please check yours.
geposted Mon 26 May 08 @ 12:02 pm
