adjustable fonts and automatic ripping capabilities in our next upgrades
geposted Wed 28 May 08 @ 7:31 am
you can change the font size and colour in the skin your using already, just go into the xml file, if you need any help in doing this just let me know, i could also make you a jpg if you wanted your name displayed
i use a seperate ripper when getting tracks off my mixmash dvds
geposted Wed 28 May 08 @ 10:48 am
That's cool Tayla. Would you be able to show me how to do that? I use Format's V-Mix 5.2 single instance, resolution is 1280x1024.
geposted Wed 28 May 08 @ 2:46 pm
hi john, could you give me until tomorrow and i make a vid for you on exactly how to do it, its nearly 10.30pm over here and i still got a bit of catching up to do, also if you like in the mean time post whatever you want to see in the browser window or your ideas and i do a test sample for you... or pm me, hope that helps
Tayla
Tayla
geposted Wed 28 May 08 @ 4:21 pm
It is quite easy really John, Tayla talked me though it a while back,
They make the skins look even better. Tayla will sort something out for you ;)
geposted Wed 28 May 08 @ 4:42 pm
